Probably have a few around, but 30 is going to take a while to gather. And the three-ways will be rare . . . You can get modern triplex stacked switches in single pole if gangs are limited, but I think this is going to be a difficult project.
What are you working on?
1st listing on the left and the 6th if you count from left to right, down.
Legrand
I won't comment on the supplier!![]()
Do you have any energy codes to comply with?
Here if this was a remodel job most likely those switches would all be eliminated and replaced with some other lighting control system.
The last library I was involved with had all the switching at the main desks with occupancy and lighting sensor through out.
There is no image available, from left to right counting down to the 6th place
(or images)
http://www.legrand.us/PassAndSeymour/Switches/Commercial/Industrial-Grade/PS20AC3REDL.aspx
Gives this definination of the 6th item(as stated above "3way Lock Switch, Back & Side Wire, 20amp 120/277vol,t Red (Key can be removed in both positions)" But the title is on the 6th item "Industrial Extra Heavy-Duty Specification Grade Lock Switch Back &... "
I'm trying to locate replacement despard locking switches in 3way and single pole configurations......anybody know where I might find some? CED says P&S doesnt make the locking type anymore....I need around 30
Thanks Cadpoint but it doesnt appear to be a "Despard" Interchangeable switch
I love it as the more information comes forward
www.passandseymour. com comes up as this has simple looking toggle non lock switches in they web pages your item name will show up as such "Despard", they also have a discontined page, your word is not in there. You can find discontinued item by using it with-in their search feature.
Sorry, I wasn't more help.
For those who need to see a pic or 10, go to Google, click on "images" and type in "despard switches". Voila! (Not "walla'!")
So the P & S 1091-GRY is not a lockable despard switch? Oh, it's not 3-way.![]()
Check out this web site. Kyledesigns.com. They have despard 3 ways for $ 17.50 each
