- Placerville, CA, USA
- Retired PV System Designer
The evidence seems conclusive that nobody's making 4 way despard switches. If the 4 way switch you need to replace is in a box with one or two switches, you can replace the 4 way switch with two 3 way switches, and connect them with a piece of wire through a hole drilled in each switch handle, like a a 220V circuit breaker. The wiring looks like this:
x------,---------
---------x |
x---,--|---------
x---' |
---------x |
x------'
The schematic above is not what I typed. The blog software removes consecutive spaces. Click on "reply with quote" and then click on "switch editor to source mode". I looked on Google images. Dozens of wiring diagrams for hooking up 4 way switches. Not a single schematic of what's inside the switch. Sorry I don't have a scanner to attach a drawing.
Try putting ASCII art inside CODE tags:
Code:
[FONT=Courier New] x------,---------
---------x |
x---,--|---------
x---' |
---------x |
x------'
[/FONT]
You may still have to adjust a little after previewing the displayed result, but it is a lot better than the default text format.
