Hello.
Can someone please direct me to disconnecting means and 3 way switches for detached garage.
Decades ago with the circuit being from either the house or garage you were able to run a 3 way between the house and garage and control a light on the house or garage or both.
Then things changed and you couldn't. I never understood what was the requirement was so I just let it go, but now I would like to know.
I'm looking at detached building and it's talking about transformers.
Disconnecting means is bringing me to separate building on same premises 250.32D which brings me to 225.32... which I think it's there someplace but not seeing it??
My questions are, Detached Garage Residential:
Can a panel be main lug 6 circuit max? Or does it need to be main breaker.
Does a single 120 volt need a disconnect? If so does a single pole switch placed either indoor or outdoor suffice?
Does a 3 wire 120/240v multiwire circuit require a disconnect? If so does a two pole single throw switch placed either indoor or outdoor suffice?
3 way switching between the house and garage..... where can the circuit be fed from ( house or garage or either or neither ) and can the lighting outlet be installed on the house or garage or both?
Thank you
Thank you
