First, I DO NOT want to start a one up battle of the minds. Lots of smart minds here I'm sure that's hazed with different opinions, haha.
Facts:
I purchased my home with a detached workshop 200' from main house located outside of city limits in Tennessee.
Built 2007.... I did not build any of it!
100A panel in the shop wired straight to the main home panel to a 50A CB I believe.
NO gas, telephone, water, sewer, cable, no overhead structures...etc. Just power wires from shop to home main.
Direct buried (aluminum) feeder wires (no conduit)......3 aluminum wires total. 2 hot and a neutral. No dedicated ground back to home main.
Also, No ground rod is installed at shop.. anywhere??
I didn't install it, bury, modify, repair, or approve this set up, so please go easy on me.
This shop sub panel has neutral/ground bonded and No green neutral bonding screw that I can tell.
I have 120V and 240V equipment in the shop that I use.
I have read (250.32) current code and understand 3 conductors, one ground is the rule...4 wires.
I can't run all new wire at the moment, and for sure cant snake a ground back to the house.
I just want to know if this the "safest" set up possible (in this situation?)
Is this is acceptable under the (old way) until I can afford to update the wire.
The ONLY reason I noticed this is because I had to install an additional CB in my shop panel for a new light and was like :blink:Hmmmm???
Thanks in advance and I hope I have provided enough information.
Mike
Facts:
Mike
