Detached unit Electrical
td1236
California
Customer has a 10×12 shed that was converted into an office. They want a plug circuit and a lighting circuit. Since the shed is detached, does it need to have a subpanel?
If you wanted to have a separate circuit for the lights and receptacles, you could run a MWBC and put a double pole switch as the disconnect. Or if both on same circuit, a single branch circuit and a SP switch.
