Determining wire sizes
prattz99
Long Island NY
Hi i'm studding the code trying to make a possible carrier out of the trade and I don't understand how to determine wire size for long runs. I know you need to factor in length of the run and the current used but I just don't get it, is there a table you use or a formula voltage drop? I'm just at a lose with it all any help would be of great use. Thanks
Welcome to the Forum:
If you go to Mike Holt's home page and look (in the free stuff, as I recall) you will find a formula for voltage drop.
Once you have calculated your load, you can plug in the numbers and it will give you the wire size for a given % of drop.
Keep in mind the NEC has suggestions on voltage drop, but there is no NEC requirement to keep it at any particular %. (see NEC 210.19)
Voltage drop is dependant on several variables
One reason that there isn't a convenient table is that length, wire cross section or size and amperage or load all contribute to the calculations for voltage drop.
