I have an outdoor above ground diesel pump to wire. The tank sets inside a cement containment area. The pump motor will be installed on top of the tank. Do i treat this the same as gasoline? Do i need rigid conduet with seals on both ends? And do i run rigid pipe to the motor. Thankk You
