I'm trying to understand the difference between a VFD's minimum frequency and its starting frequency?
The way I understand it, is that the VFD's minimum frequency is the lowest frequency that the drive will run at during normal operation (exluding starting) and will not operate below this speed except for starting and stopping.
I believe the drives starting frequency is the frequcny that the drive will start at when staring a motor and ramping it up to base speed. For instance if I set a starting frequency of 8Hz the drive will start at 8Hz and start to ramp from there as opposed to starting at essentially 0Hz and ramping up to speed. Do I understand this correctly in regards to setting this starting frequency?
What would be a reason for setting this starting frequency to some value as opposed to starting from 0Hz?
