bgowg
- Sterling Heights,MI.
- Retired master electrician
2 digital clocks connected to same circuit in condo both clocks would sometimes gain around 15 min. almost seems like 50Hz instead of 60
Same here. Fast is chosen over slow for wake-up alarm reasons.I have a digital clock with battery backup that runs fast whenever power is lost causing it to run on the battery.
Maybe there was a power outage, and they sped up on battery.2 digital clocks connected to same circuit in condo both clocks would sometimes gain around 15 min. almost seems like 50Hz instead of 60
If the clocks get their timebase from the AC line, there might be noise on the branch circuit that is creating additional triggers beyond the intended ones at the zero crossings of the AC waveform. And this would effectively speed up the clock. A good quality clock would have adequate hysteresis and filtering (and possibly also a phase locked loop) to prevent such false triggering, except under relatively severe interference.2 digital clocks connected to same circuit in condo both clocks would sometimes gain around 15 min.
I am leaning to that option of line noise or interference the clock are 2 different vintages 1 new 1 older model ,thinking back before retirement I had a problem within a half a mile of this location with a county building computer room rooftop condensers alternating system.Several comm towers on county building would actually energize the alternating cycle relay.It was looked at because of difference in hour meters on units.I actually saw the relay energize with both units at rest.Thanks for all the feedback from everyoneIf the clocks get their timebase from the AC line, there might be noise on the branch circuit that is creating additional triggers beyond the intended ones at the zero crossings of the AC waveform. And this would effectively speed up the clock. A good quality clock would have adequate hysteresis and filtering (and possibly also a phase locked loop) to prevent such false triggering, except under relatively severe interference.
Is there any appliance being used on the circuit with the clocks such as a vacuum cleaner, blender, washer, etc.?
I just noticed that zbang mentioned noise as a possible cause as well.
