Electric-Light
No you cannot! Go back and read 725.136(I)(1). If it was as easy as you say you could use 4-wire MC and if that were the case why do you think wire manufacturers went through the trouble to produce luminary cable MC?
-Hal
If all the components used allow for it, you can reclassify them as class 1.
A plausible explanation for your question. It's not always desirable to do so. Using luminary cable allows the control side to remain class 2. This allows the power and control to run together for a portion of the system and allow it to be separated at a node and allow it to branch off as class 2 wiring if needed. If you did reclassify, every piece of control, connection and wiring have to be treated like they're live at line potential.
