The only thing I can think of that would limit you from ganging the 2 together would be IF you were dealing with 277V/480V systems. See 404.8 (B) this is for snap switches, but you may not install switches ganged with similar devices if a voltage potential exists of more than 300 V between devices. I don't know if your dimmer or speed control would fit with an installed divider between them. Again, this is ONLY if you have 277V lighting that you would have to start considering this.
milwaukeesteve said:It does state 'similar devices'. What is a dimmer but a similar device to a snap switch, in reference to lighting?
milwaukeesteve said:I like that answer.
