jetlag
- Eatonton, Georgia
Please Help . I always thought there was no way to use a dimmer on a 3 way because if someone left the dimmer turned all the way off on the end feeding the light fixtures that you not turn it back on from the other 3 way switch until you adjusted the dimmer to let at least some current to come thru the dimmer . A customer is telling me I am wrong . Some one told me they think it works if you install the 3 way dimmer on both ends in place of the regular 3 way switches . Maybe the 3 way dimmers are made so they wont turn all the way off to break the circuit feeding the fixture . if so I can see how it might work . I do have a dimmer on a 3 way at my own house but it is just a regular dimmer installed after the current has left the way switch that feeds the lights . but I have to remember to not use the dimmer to turn the lights off but turn the lights off with the 3 way switch , Please help . Thanks
