I recently installed several LED retro trims and I can't seem to get acceptable dimming even with the manufacturer suggested dimmers.
I also tried other non recommended LED dimmers and they failed as well.
Dimming range is fine but I consistently getting noticeable humming that's irritating when it's extremely quiet in the building.
Finally out of frustration I used a relatively inexpensive common incandescent dimmer that got rid of the humming .
The low end dimming was reduced a bit but there's no sound at all.
Would there be any concerns in using a non LED rated device? Wattage rating falls well within the limits I need.
Thanks
Thanks
