wireday
- New England
- Master electrician
Do they still make two wire ballast that will dim? I want to retro an existing light to dim,I just want to replace the switch with dimmer and ballast in the light.
Thank you Kwired, I thought I heard in my last code update that line voltage LED was not to be used until further notice, Also I am quite certain at some point regular T8's would end up being installed by someone. 277volts.
What code update? 2017 is already out, 2020 isn't published yet. That leaves you with local amendments being what may have an impact.Thank you Kwired, I thought I heard in my last code update that line voltage LED was not to be used until further notice, Also I am quite certain at some point regular T8's would end up being installed by someone. 277volts.
