Dimming can lights
I figure thats another thread entirely but I tend to agree with you. :smile:
That's gonna be a huge problem when the old-fashioned bulbs are outlawed (2012, isn't it?). Bazillions of existing fixtures installed all across the country, and not a bulb that will legally work in them.
Sounds like a great market is opening up! :smile:
The MR16 ?
Is that a Reflector, incandescant, with 2" reflector, Low Voltage ?
It is dimmable with standard dimmers.
I have installed them, but they have a double Pin base
(larger pins for 120V and smaller pins for 12V).
I am curious how they would mount in a recessed light fixture.
Is there an adaptor for the Edison Base socket ?
The MR16 ?
I believe when the MR 16's were posted they meant you would have to use a low voltage can. Yes they are dimmable. I don't know of an adapter but there probably is one somewhere.
Unless the fixture lists CFL lamps, then how can you even 'legally' install a CFL?:confused:
I'm just guessing here, but I would say that is probably taken care of in the listing of the CFL. Basically, the listing for the lamp probably says that the is safe to use as a direct replacement for an incandescent lamp. So there is no need to have a fixture that is listed for use with CFL's, its the other way around.
Steve
So with the plug type CFL's does anyone know what the PL, PLT, PLL, and PLC mean? I assume the P stands for Plug.
Steve
