David Fernandes
How can you avoid dimming lighting while initially energizing equipment.
Too much load already on the circuit when you turn it on.
Sometimes, plugging into a different circuit will 'cure' it. Otherwise, either learn to live with it, run a dedicated circuit or vacuum without the lights off.
Learn to live with it would be my suggestion, a dedicated circuit will not necessary fix the dimming complaint.
Yea, but work is work, and work = money.:grin:
Yeah, but what do you tell them when the lights still dim after plugging into a new $400 receptacle?
What if you did a service upgrade and it still dimmed????? And then you found out it had a loose connection on the power company's transformer nuetral???????????????
this would actually be the same as saying: "vacuum with the lights on"
he had said for you too vacuum without the lights off. Well in order for you to vacuum without the lights off you would have to turn them on. Which is what is usually the case anyway. The lights are usually on already. I was just picking on him. What he should of said was vacuum with the lights off.now I'm really confused. Doesn't take much.:smile:
