B
bthielen
Guest
I found it interesting that residential direct burial depth is only 18? under gravel driveways and parking areas while across my lawn requires 24? of depth. This sounds backwards to me. It seems to me that under a driveway there is a higher chance of gravel that could cause damage to the wire and in my case that is precisely what I ran into when I dug the ditch to my new pole building. I went 24? even under my driveway and still found gravel. I decided to encase the wire in PVC conduit to add a little abrasion resistance under the driveway. Areas that are not under my driveway are clay soil with very little if any sand or gravel. It would also seem too that living in Minnesota where frost heaving is common there is a greater chance of movement within the soil throughout the year, especially under a roadway, driveway, or parking area. So, my first questions is why the difference in depth requirement?
I also ran into another situation. I was aware of a 12awg run supplying my well pump that was installed by a contractor in 1991. When I got near the area where I expected the wire to be, I began digging my trench by hand in anticipation of locating the wire. There was a tree nearby and I had been cutting roots all along. Yes, I found the wire when I thought I was cutting through a tree root. It was only buried about 10?-12? deep. This was upsetting because here I am being so careful to bury my wires at a depth of 24? and find that when I hire someone to do it they only bury it about 12?. I inquired of our master electrician where I work and he suggested that circuits less than 30amp only require 12? burial depth. I can?t find any reference to this in the 2002 code and to my knowledge Minnesota does incorporate the NEC. Is this correct or perhaps was this was correct in 1991 but is no longer? If it is or was correct then I would be in the wrong with my criticism of the contractor's work. I would be interested in knowing where this is in the code.
Thanks,
Bob
Thanks,
Bob
