I have a main panel that is going to be turned into a sub fed panel. I therefore need to run a seperate grounding conductor to it. The run is currently direct burial with PVC stub ups. Can I direct bury dual listed thhn/thwn? I see it is listed as dry and wet locations. Reasoning: (which may be invalid ) if I can do this with bare wire, what difference would be jacketed wire with a wet location listing?
Thanks in advance
Magnus
Thanks in advance
Magnus
