MarioSpina
- Akron, Ohio
I have a building that is located inside a secure fence line and the utility is requiring the meter to be located outside of the fence, the problem for me is that the AHJ is requiring a disconnect on the load side of the meter right next to the meter outside of the fence.
Normally the service disconnect is located inside of the building, having the service disconnect outside that far outside of the building causes me problems because of numerous ground connections which we normally make to the neutral/ground bus. I am not looking for a debate on these connections we make, just looking for something in the code that would allow for the service disconnect to still be located inside of the building and what should be done at the outside disconnect if this is allowed?
Thanks!
-Mario
Thanks!
-Mario
