ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician 2020 NEC
That section would also allow a raised platform, or hook stick.The handle of the disconnect should be at 6'7" in the on position 404.8
In some cases the disconnect is permitted to be accessible and within sight to equipment which could be more higher than that
Could 4 of those boxes be replaced by 2, with DP DT disconnects, or transfer switch to batteries?Middle right is a fused disconnect (next step is connecting to the SES - load side, direct to the bus work) The utility company will not put their lock on a fused disconect. Plus the top disco is at the output of a meter they want isolated(able)
