Brandon Loyd
On your standard 208-480VAC, 3 phase, fusible or non-fusible disconnect, you often find an bypass screw/switch to defeat the mechanical interlock. This allows you to open the cover without disconnecting power for inspection/testing/troubleshooting purposes. On a lot of older equipment you cannot find these bypass screws/switches, as I assume they were not designed that way. Does the NEC currently require you to have a way to defeat these interlocks? I would imagine this is a common problem these days for Infrared inspections or gathering field data for Arc Flash analysis.
