I will be installing a instant hot-water heater. It requires 3, 50 amp, 240v circuits.The main panel is in a seperate location. I have installed 1 of these in the past. I installed 3 seperate 60amp non-fused disconnects. My field manager is telling me that the disconnects are not necessary, that breaker locks in the main panel is sufficient. I have combed thru Art. 422 and cant find the answer. Art 422.31 (a) is the closest I can come to an answer. That would make my Boss right, However I have been told in the past that if the water heater is not located in the same room as the panel then it requires a disconnect. Please help?
Thank you.
G-
Thank you.
G-
