I'm sure this is a violation but not sure where in code. We installed a three stop hydro elevator. In order to get proper phase sequence the installing electrician(for the power) switched two legs on the disconnect switch. It is a 480 volt installation with color codes BOY. The electrician swapped two load side wires, so now the BOY on the load does not match the colors on the load side.
Although it is easily corrected by reidentification, the installing electrician does not feel it is a violation. His argument is that it is common to swap phases to get proper motor rotation. Is there a code that states that line and load wire identification must match?
