- Placerville, CA, USA
- Retired PV System Designer
It seems simple and clear to me that if you are required to indicate phase and voltage and you choose to use color to do so, then any time you swap two line conductors anywhere except where they connect to the load equipment (e.g. at the peckerhead) then you are required to tape (or retape) the downstream wires to preserve that phase identification.
I agree that as a practical matter you may have good reasons not to swap at the peckerhead and it may be anywhere from annoying to impractical to retape. But that does not change the letter of the code.
jumper: You appear state in your first response that it would actually be a violation to retape the downstream wires. I must disagree. The color for A must remain the color for A even though at some point in the circuit you have swapped A and B. That means that the downstream color must change.
If that is not what you meant, then it may be some confusion about which of the OP's questions you answered, i.e. was it "Is the electrician right?" or "Should the colors be corrected?"?
