Grouch1980
- New York, NY
Hi all,
In any setup where you have disconnect switches feeding solar PV arrays, for example, say you have a service disconnect switch feeding a step-up transformer, which in turn feeds a secondary disconnect switch, which in turn feeds an AC combiner panel that feeds the solar inverters. Do the fuses and switches inside the SDS and secondary disconnect switch have to be flipped? Since power flows from the PV arrays to the service, do the switch mechanisms inside the disconnects now have to be on the line side (the side with the PV arrays), and the fuses on the load side (the side with the utility)?
