solardirect
New member
- Sarasota FL
We install Battery Based Storage with Solar Energy Systems - this requires moving circuits into a dedicated critical loads panel (both the L1 and Neutral wire for each circuit breaker) in order to isolate them from the Main Service Panel. In a recent installation, we encountered an older home (with a new owner) with some neutral issues - so we disconnected every single neutral in the Main Service Panel, and all of the loads still were energized from their breakers without any neutrals hooked up. Most if not all circuits are run in EMT conduit, it seems that maybe the metal conduit could be acting as the neutral even though they are White Neutral wires for each circuit.
Our specialty is solar and batteries, so this electrical issue has us stumped. Hoping someone can offer advise on how to troubleshoot or explain what might be happening, and any actions needed to correct it. Also, is the issue a safety/fire concern? Obviously the homeowner doesn't want to hear that his entire electrical service could be installed wrong, but having some third party substantiation would help build trust that this it is not a problem often encountered (unless it is), or that we created.
