shortcircuit1
- USA
Lets say if you have a garbage disposal and it is just hardwired without a receptacle under the sink.Per NEC i need to provide a disconnecting means with in sight.Now there is a control switch above the counter which is used to turn ON/OFF the disposal.So can i use that a disconnecting means or do i need to provide another disconnecting means which i dont see a reason why?
