Disconnecting means for packaged equipment
Isaiah
Baton Rouge
Electrical Inspector
We have an 480V air compressor - packaged equipment-with no local disconnecting means but there’s a lockable disconnect switch upstream approximately 200 feet away, out of sight of the skid—as I recall this is sufficient and a local disc is not required… comments
If there is a motor controller involves you must have a disconnect within sight from and not more than 50 ft from.
Right, but the controller is on the skid. So the motor is within sight of the controller
