treyp3
- Fernandina Beach Fl
I had to move power for an AC condenser. Homeowner had his AC by the back door and moved it around the corner. AC company hired me. I ran conduit underground from new AC location to existing disconnect. The disconnect is about 45 feet away, not line of sight. The disconnect is pull handle type. I figure since you can pull the disconnect handle out and take it with you it should be good even though Code says it must be lockable to be out of sight. I feel like its better than a breaker lock the way I did it, and if you walk away with the disconnect handle the circuit is essentially locked open. Do you guys think this would fail inspection? AC guy is not happy.
