There are four machines that do not have disconnects on them. There is an on/off switch that kills power to the machines and the circuit breakers for the machines are clearly labeled in the panel less than 20ft away. However the motor/generators for these four machines are on the oppisite side of the wall in another room. If something were to happen to the generator section there is no disconnecting means within sight. Can we put a disconnect by the generators? Also can this disconnect be after the motor starters?
