dispenser conversion from gas to diesel
mpd
has anybody ever dealt with converting a regular gas dispenser to diesel, i am being told nothing will change, no electrical work required other than some fuel piping changes, does anybody know if this effects the listing of the dispenser
I believe you will find the dispenser is "listed" to handle either gas or diesel and possibly E-85. The only wiring change would be if it is a dispenser, you would need to turn on a different submerged pump if the fuel piping gets changed. If it's a suction pump, no electrical should be necessary...... unlesss :) .... the site has above ground tanks then it's possible there may be a solenoid valve at the tank (for anti-siphon) that may need some wiring or wiring change.
