Stevenfyeager
- United States, Indiana
- electrical contractor
What distance works for you between recessed lights and ceiling fans? To avoid strobing effects. Assuming worst case scenario of 52” fan. Thanks
LED will be making a difference nowadays.Flood or spot lamps?
3 feet from the TIP of the fan blade. That's what I was taught.Benn awhile since I dealt with that. I gave as much clearance as possible but I think I gave at least 3 feet from the fan. Most cans didn’t have much more spread than that if I recall correctly.
