iaov
- Rhinelander WI
I believe the proper name is a "goon spoon". They come in skinny and regular sizes.MF Dagger said:I just call it a trenching shovel. I have heard drain spade however.
mdshunk said:Ah-hah, "drain spade".
I like that name too!masterinbama said:Ive always called it "The Helpers Tool"
I remember in the 'ole days when they were not available, guys would take a cutting torch to a regular round nose shovel and cut the two sides off down to the width that they wanted.
thats a sharp shooter.View attachment 2274 thats a trenching shovel or crumbermdshunk said:Ah-hah, "drain spade".
iaov said:I believe the proper name is a "goon spoon". They come in skinny and regular sizes.![]()
I'm not sur you could dig a trench with that but it might be fun to watch a helper try!Dennis Alwon said:A goon spoon has a spoon on the end. Check it out Operating a goon spoon :smile:
This would be better for scooping a deep ditch if the blade was bent near around 75 degrees.220/221 said:
LarryFine said:This would be better for scooping a deep ditch if the blade was bent near around 75 degrees.
