This is an offshoot from another thread on this board, ?Single phase / Two Phase Discussion?.
I posted this on Post #39
So I made the statement, ?There is no 2phase load.?
But Engy made a statement in Post #40 that got me thinking.
?It ain't two phase - doesn't have two phases 90degrees out of phase.?
I?ve never dealt with the 90? out of phase animal but going way back in my memory to the time when I was learning theory, I believe that I remember how this thing worked.
Rather than having a capacitor introduce a phase shift to provide starting rotation, I think I remember that this one has 2 transformer phase coils with voltages induced 90? apart. . One end of each transformer is brought together to provide a 3wire output. . The motor that would run off of this supply would also have 2 separate coils. . The phase difference between the motor coils would not only provide starting rotation but add torque during the entire motor running time.
I believe the common wire is grounded but there?s only one voltage. . Hot to hot is the same voltage as hot to ground. . Pick any 2 of the 3 leads and you get the same voltage as any other 2.
If I?m remembering all of this correctly than there is such an animal as a 2phase load. . This would be different from the 120/208Y 3wire wye supply with one of the 3 transformer coils missing. . It supplies dual voltage and the load uses either one voltage or the other, so every load connected is a single phase load. . Even appliances or other equipment that use both voltages, use them on independent functions within the appliance, like 208v heating element totally separate from the 120v controls. . So both loads are single phase loads.
But this rare 3wire 90? 2phase coils appears to supply the only example of an actual 2phase load that I can think of.
Can anybody either reinforce or correct my memory ?
David
dnem said:Reading this entire discussion up to this point has lead me to the conclusion that the word ?phase? has more than one meaning in our electrical industry and in our discussions and can not have an agreed upon usage until it is defined more specifically.
I?m seeing 3 different definitions being used:
1) phase coil, which can number 1, 2, or 3 (and theoretically higher but not found in reality)
2) phase load, which can number 1 or 3
3) phase conductor, which can number 1, 2, or 3
A single phase coil is connected to a single phase load.
3phase coils are connected to a 3phase load.
But 2phase coils are connected to a single phase load. . There is no 2phase load. . And that?s where most of the dispute is coming from.
engy said:You can only connect 1-phase loads to this animal, which is why I call it single phase.
It ain't two phase - doesn't have two phases 90degrees out of phase...
It ain't three phase - cause we only brought two of the three phases...
Maybe it's not single phase either![]()
David
