Yup, and if it has an integral VFD or starter then I would expect it is has a disconnect already. If that is the case I see no need for a safety switch.
Now if all I got is a pressure switch at the compressor and a starter in a MCC bucket (or hung on the wall) 50' away, then yes I want that safety switch at the unit even if it isn't required by code.
The compressors manufactured by the company I worked for that had conventional motor starters never had a disconnect.
The ones with VFDs normally did.
