- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: Do modified-sine waves affect overcurrent protection?
Mark, can you elaborate?
I wasn't present for the big one. I only had my garage outlet experience mentioned in the first post of the thread, and I didn't hang in there long enough to knock the inverter down.Originally posted by mprairie:
George, You didn't mention how long it took the inverters to shut down.
Why would it care about an out-of-phase condition on a line-neutral (or ground) fault? Wouldn't normal 240V loads, or a line-to-line fault, bring out this beast?It may be the inverter protection is reacting to the out-of-phase condition under load faster than the CB.
I was thinking that would be fruitless. But, with this predicament I'm having, it makes sense that I would get a meaningful reading with an ampclamp, since the entire process (of the breaker kicking) has been slowed so far down.Maybe you could amprobe the circuit to get a better picture of what is happening.
No, I diagnosed it over the phone and told them not to use the griddle, and to call the appliance supplier to repair it. The range was never in-place and malfunctioning while I was there.Did you find the short on that stove ignitor circuit?
