LarryFine
- Henrico County, VA
- Electrical Contractor
GFCIs pass all circuit conductors through a ring. As long as no current is leaking out of the circuit, no voltage is induced in the ring. If any current does leak out, a voltage is developed and detected.i don't think it would be possible as current could be equal on both legs or some could be returning on neutral.
A single-pole GFCI works the same way as a multi-pole unit does. In fact the load circuit need not even have a neutral conductor at all. The main requirement is that the supply has a grounded conductor.
