bigal1
- United States
Thought I heard or read somewhere that all panelboards were required to have a grounded "neutral" conductor if available on the supply side. Anyone know if this is true?
250.24 Grounding Service-Supplied Alternating-Current
Systems.
(C) Grounded Conductor Brought to Service Equipment.
Where an ac system operating at less than 1000 volts
is grounded at any point, the grounded conductor(s) shall
be routed with the ungrounded conductors to each service
disconnecting means and shall be connected to each disconnecting
means grounded conductor(s) terminal or bus. A
main bonding jumper shall connect the grounded conductor(
s) to each service disconnecting means enclosure. The
grounded conductor(s) shall be installed in accordance with
250.24(C)(1) through (C)(4).
