mstrlucky74
- NJ
The 2g we use are 37 cu. in
The 4 11/16 x 2 1/8 is 42 cu in
But the 4 11/16 x 1 1/2 is 29 cu. in
So I'd go with the 2 1/8" deep
Does the mud ring count toward cu. in. ?
never seen such a box, but looks like it needs some kind of adapter ring to make it "2 gang" but is physically big enough that there likely is such a thing as a "3 gang" adapter ring for it as well
That's a pre-ganged box... with cover, it's mostly used for surface mount work. BTW, what's pictured appears to be capable of four devices, though a 2-device cover is probably available. Their okay for surface mount when you have greater than two devices especially with common wiring.
It doesn't look to me like it has device mounting provisions though and likely needs a mud ring or raised cover to attach devices to.That's a pre-ganged box... and its mostly used for surface mount work. Their okay for surface mount when you have greater than two devices especially with common wiring. With only one or two devices, its more common to just use a standard square box with a raised cover (the one in OP is a square box, not a 2-gang box, but rather will hold 2 devices with the appropriate mud ring or raised cover). If you wanted, you could just nipple square boxes together, but a pre-ganged box with cover keeps device 'gang' spacing and looks better in the end.
Typical gang or gang-able boxes are for flush mount devices, and the device mounts directly to the box, cover to the device.
Devices are mounted to covers, which all I've seen are flat metal plate covers.It doesn't look to me like it has device mounting provisions though and likely needs a mud ring or raised cover to attach devices to.
Wow adjustable tooHere is one which supposedly will fit
http://www.tnb-canada.com/en/catalogues/online/comresconstruction/pdf/c1/boxes_12_eng.pdf
