Re: do you have to be in the electrical industry to ask a qu
thank you for stating what questions you allow. I did search, but couldn't find the answer to my questions.
We purchased a 95 year old house earlier this year that we had inspected by a Norman, OK NACHI licensed inspector. The previous owner stated that the house had been rewired and a licensed electrician hooked it up to the 200 amp panel.
In having a plumber repair a leak, we found the house has a mix match of wiring. The plumber got shocked by a hanging K&T wire. There is K&T, thick black wires, white wires, etc. I'm sorry I am not knowledgable in wiring.
We had one quote of $19K and that the entire house needed rewiring to replace the K&T, but he didn't want the job. A second electrician said, "to feel the knob and tube to see if it is brittle, and gave some tips on running a new wire, but he also didn't want the job.
It is a 2 story, 3,000 sq ft home with crawl space and attic access. To make matters worse, the house has wood shakes under asphalt shingles that the inspector also missed, and 2 layers of batt insulation in the attic, which the local inspector says HAS to be covering K&T with K&T in the house.
We are going to file a formal complaint with the state's licensing office for home inspectors, so that he won't be as careless in the future, but we are left high and dry as far as the expense. His contract said it would only cover any problems found in 90 days. We found the problem in 95 days.
Because we can't find an electrician that wants to touch the house, we inquired at the local building inspectors office to see if we could run the new wire since we have the ceiling exposed where the wiring is and have a licensed electrician hook it to the box, the way the old owner did. Everyone in town from Lowes, to lawyers says you can run your own wiring. We found out that is untrue.
The inspector said we cannot do any wiring ourselves, the house has to be entirely updated with new yellow, 12g wire/all new 20 amp breakers, and that the insulation in the attic is unsafe. He was very argumentative, accusing me of living at a house further down the street that is having work done on it without a permit, so the conversation got very confusing. I asked what work a homeowner can do on their home in general and he said they had a list, but he couldn't find it. I left his office very confused and frightened.
Another electrician is coming out next week, and hopefully he will consider the job. The inspector said the only way we can run any wires ourselves is if we want to do some sweat equity work WITH the licensed electrician present.
Questions:
- Would you as an electrician allow a home owner to help you run wires? The house has lath/plaster/paneling walls. It is not a historic home and has been updated through the years. I have no problem with cutting holes wherever they need to, to do their job. What we can't do is dismantle the entire house, because of the cost to put it back together. Also I am 71 years old, so I can only do so much, but could hire a helper for the things I can't help the electrician with, if that will help us be able to afford to do the work.
-is it true that all 14g wires have to be replaced with yellow 12g? The inspector kept stressing that even 2 yr old wiring from the previous owner would have to be replaced. But he did say, because we are living here and have a power meter he can't force us to update anything. It's if we replace that wire in the ceiling that went to a ceiling fixture (with no box) we will have to update the entire house wiring.
We are overwhelmed that our inspector missed obvious flaws in the wiring and roof. We are low income retirees and were counting on the professional inspectors competence, and the sellers disclosure of "good" upgraded wiring, in our decision to purchase this house. Now it has become a nightmare.
As much as we want to bail and put the house back on the market, we don't want to pass along this mess to a future buyer. There is no way we would sell this house and not disclose the problems as the previous seller did. We would not wish that on our worst enemy.
I'd rather not state the town I live in, but our town does follow these standards:
International Building Code
ICC Electrical Code?Administrative Provisions
International Energy Conservation Code
International Existing Building Code
International Fuel Gas Code
International Mechanical Code
International Plumbing Code
International Property Maintenance Code
International Residential Code
We want to do everything legally and safely and need to know what to expect as far as cost, to see if we can even get this done, or be forced to sell at a loss. I do know we can't live here if the wiring is unsafe.
There is a panel below the 200 amp service panel that our inspector entirely missed. There are 3 breakers there with only 2 wires coming into the box (ungrounded). The garage is also ungrounded, which he missed. The box was in plain view, which really upsets us.
Thank you for any encouragment you can provide. This town is full of "handymen" that WILL do wiring, plumbing, you name it. We have turned them all down (actually they run when we mention permit!) and want to hire a licensed electrician, if we can find one that will work on old houses.
I give you guys alot of credit for your expertise, continued education and licensing, and that you are willing to work in such a hazardous profession.
[ December 09, 2005, 04:39 PM: Message edited by: michael_k ]
