Re: do you have to be in the electrical industry to ask a qu
I would talk to a lawyer that has actual knowledge of your local and state laws regarding assumed liability and home inspectors. if there is any proof of collusion between inspector and homeowner, I doubt that any limit applies, except time from discovery. Most current law is tending toward 10 year limits. Even if inspector is out of town, his insurance (errors and omissions) is still in effect.
there are many tips about "old work" on this site (old work is what you have), use the search function. cutting and patching plaster is not amateur work.
It sounds as if you have punched a lot of buttons on the part of the ahj. If your representation is accurate, he is not fit for the job. i suspect that somewhere he has had his toes stepped on by you, or someone he thinks is you. He still shouldn't act this way, but a way out of this problem is what you need, not commiseration.
Others have suggested that you get an electrician to conduct a real inspection. i would suggest that you also have this electrician see what is up with the ahj, county inspector, or building offical as the whole house rewire is not our common experience as a requirement. he may believe that so much illegal work was done that it is in your best interests. I would try to find out without being argumentative or confrontational, maybe even apologetic (even assuming it's not your fault), what is really driving his attitude.
You are going to have to work with the county no matter what, and being terrified of the building department is not acceptable if you are above board. Solve this problem along with the inspection and a claim against the inspectors insurance co. should just about fix you up.
paul
paul
