Yes. But that doesn't invalidate my other point.Seals are like locks. They only keep out most of the honest people.
There are many different power companies in the US each with their own rules. Few if any allow a customer owned and / or controlled disconnect switch ahead of a meter at typical homes with 120/240 or 120/208 volt services. In almost all cases the power company has to literally cut a wire or open the primary to a transformer but that will usually knock out many homes.
Tradition I can understand.
The theft not so much.
You just as easily disconnect the live side of the breaker as the live side of the meter.
Here the live side has seals that you would need to break to steal.
Allow me invalidate that for you.Yes. But that doesn't invalidate my other point.
The way it is arranged, you can't get to the terminals between the breaker and the meter.Allow me invalidate that for you.
Service drop -> Meter -> Main:
To tap ahead of the meter here you would have to work it hot. A deterrent for some.
Service drop -> Disconnect -> Meter -> Main:
To tap ahead of the meter here you can open the switch to work in safety. So easy even a caveman could do it.
Won't work for me. Unless I control the switch, I want a visable air gap under my control. If you can't disable remote operation you are not safe.
Shoot, I test the load side with my wiggy even AFTER I pull the meter:thumbsup:
In answer to the original post: NO
I agree. To me this is no different that, say, relying on a motor starter that the control circuit has been turned off to act as a disconnect. Of course I think most would agree that is not a disconnect.In answer to the original post: NO
Very wise indeed.Shoot, I test the load side with my wiggy even AFTER I pull the meter:thumbsup:
Very wise indeed! A year or so ago after pulling a meter on a rural meter loop I discovered one of the load side conductors still "Hot". I call these an "up/down" loop. At some time in the past they had overhead ACSR short circuit until it blew the fuse on the transformer. POCO fixed the overhead but did not realize one of the line side conductors insulation had melted into one of the load. First time for me in 30+ years.Very wise indeed.
