readydave8
re member
- Clarkesville, Georgia
- electrician
I also sometimes pretwist, but usually not. If the ends line up even and none are pushed back when starting the wire nut, and tighten down with #-in-one tool, you should have no problems.
I've also seen pretwisted connections fail when one conductor rolls back around the others and is not getting pressure from wire nut, it will work for a short or a long time.
When I take a wire nut off the condutors usually stay together, the wire nut has twisted them.
