LawnGuyLandSparky
While I have't kept the statistics to accurately determine the ratio of failed aluminum to failed copper services, I do know that it is more prevalent in the aluminum wired services. It may be because of the improper torqueing (do you actually torque all of your connections?), or it may be from improper sealing of the cable/connector, but for whatever reason, it seems to fail more often.
I don't condemn any contractor that intalls AL SE cable, that is your own choice, and it is code compliant. I also don't complain about being underbid. Sure, we lose a few just because someone else doesn't have the same costs as we do, but on the average service, the cost of copper SE cable increases our costs by about $225 over AL SE. If I lose a service change over $225, then it's my own fault for not having convinced the homeowner that I would be the better choice.
Then why not give the HO a choice to do the service in aluminum, and explain the differences? 2 prices... the Al lower and if that's what they choose you have a chance of not only getting the job, but also the good P.R. from educating the HO that the lower cost contractor is using an inferior material.
