Have a 208/240 device with an L6-20 plug (an L6 receptacle is hot-hot-ground).
This device has a built-in 110v GFCI outlet labelled ".5 amps max load". That's point five. I suspect the device is using the ground for return for 110v (but maybe they are generating 110v internally some how like a small transformer). Install instructions also state device must be externally grounded.
Does code permit this small return current on ground for 208/240 devices using L6 cordsets?
Thanks,
Thanks,
