I have installed an outside 200 amp panel, and run through conduit a  4/0 -4/0 4/0- 2/0 al feeder. the out side panel has feed through lugs on it, and a 200 amp main breaker. the inside panel has MLO and is rated for 200 amps. all circuits for the house derive from this panel, non from the out-side panel. Inspector said i need individual protection for the inside panel. my question is does the outside main breaker count for the ocp for the inside panel. Code references either for or against it would be appreciated.
