Installer
- DesMoines, Washington
I'm trying to help a friend install a 120/ 240 Subpanel of 1 120/240 main Panel Most of my experience is with my employer, which has strict rules.
When I started to draw up the subpanel connections, I noticed that the Neutral bar on the Main Panel has Ground connections and the Ground bar has neutral connections.
Since the two should be bonded together, perhaps it doesn't make a difference.
But if that were true why bother running a separate neutral and ground to the new Subpanel?
What do I not understand?
Thank you in advance
