ProcessMark
New member
I work in the retail display industry. We make point of purchase displays for retailers. We are working on a current project that involves creating a lightbox made of plastic that contains 2 bulbs, one LED, one Halogen. The goal of the display is to measure the watt usage of each bulb to show the consumer how much power they can save by using the LED bulb. The components include a Watt meter, toggle switch, the two bulbs (w/casings), a dimmer switch (w/ separate power switch), and the wiring needed to hook it all up. All of these components are UL listed themselves. My question is does this need to be UL listed? I had heard something like that if you used 8 (or less) UL listed parts, then you didn't need to worry about having the entire unit UL listed, is this true?
Any info about what we need to do for this display as it relates to UL listing or not would be helpful. thanks.
