090422-1520 EST
A small wall transformer and rectifier supply unload may dissipate 1 W, CUI 12 VDC 300 MA output rating. Whereas a Phihong switching type 12 V 420 MA output rating is about 0.3 W. I am using a 75 W meter for this measurement and thus the accuracy is not good.
The non-switching type is now banned.
Lots of these little things do add up. However, the politicians should be talking about the big stuff. My average consumption is about 40 KWH per day. By keeping unused lights off I can generally reduce this to about 30 KWH per day.
One CUI supply at 1 W would consume about 8.76 KWH per year or 0.024 KWH per day. This is 0.024/10 = 0.24% of the energy I can save easily by other means.
What you really want to do is analyze your residual load for unnecessary loads that are always on. Eliminate the unnecessary loads. Next attack the variable loads and see what ones are being left on when not necessary. Much of this unnecessary load is lights.
To go around and unplug cellphone chargers is sort of silly in comparison to solving the problem of large unnecessary loads. In time, as you get new cellphones, the new chargers will have less residual loss.
