Article 250.8(B) states: "METHODS NOT PERMITTED: Connection devices or fittings that depend solely on solder shall not be used".
I have been designing many pcb circuits whereby I solder a power-entry-module (IEC320 type, 120vac) to a pcb, then with traces, carry the earth ground to other solder connectors to feed power to loads. All my pcb designs have met UL and CSA req'ts.
Does this practice violate above NEC article because I use solder to make ground connections ???
[pcb = printed-circuit-board, or printed-wiring-board]
